7/30/2013 9:22 AM | |
Joined: 4/29/2010 Last visit: 1/20/2025 Posts: 1557 Rating:
Hello fschwa, yes you can run the Mobile Panel 277F IWLAN without transponders. A transponder is needed to form "zones" there you can use the safety functions of the panel. But you can also use this functions if you use the "override" mode. Take a look at this application (and also search for the "override" mode in this describtion): Configuration and Use of the Mobile Panel 277F IWLAN With best regards |
