4/23/2010 9:39 AM | |
Joined: 4/16/2010 Last visit: 9/19/2024 Posts: 6 Rating: (0) |
you should modify you plc program. |
5/5/2010 2:14 PM | |
Joined: 11/21/2007 Last visit: 9/25/2024 Posts: 2325 Rating: (308) |
Hello First of all you have to find out if your system is a Modbus Master / Modbus Slave. Following Documents explain the Modbus Master / Slave Drivers for CP-524 : S5 is Master : http://support.automation.siemens.com/WW/view/en/41273 S5 is Slave : http://support.automation.siemens.com/WW/view/en/41299 Unfortunately the documentation is available in German only Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
