6/5/2017 11:02 PM | |
Joined: 9/12/2016 Last visit: 11/6/2023 Posts: 45 Rating:
Hello dear friends, I have a pH sensor that communicates with modbus rtu. As I have shown in the pictures, I communicate with modbus in the pictures. However, because I can not get the database table correctly, the values I put into the database seem absurd. How should I organize my database tablm when I insert the data according to the sensor modbus table I have added? So, the point I most often hang out is the sensor pH value float, but how do I transfer it. I would be glad if you help. Thank you. ------------------------------------------------------------------- pH Meter Sensor Modbus Table: https://ibb.co/g2Zdna Siemens S7 1200 Mb_comm_load: https://ibb.co/nO7QYF Siemens S7 1200 Mb_master: https://ibb.co/dKJona Siemens S7 1200 Database Table: https://ibb.co/dcw8na |
12/3/2020 1:11 PM | |
Joined: 12/18/2019 Last visit: 4/18/2021 Posts: 9 Rating:
How did your solution ended up looking? I'm trying to integrate the exact same Hamilton pH sensor apparently ! |
5/3/2023 4:39 PM | |
Joined: 7/11/2022 Last visit: 12/6/2024 Posts: 2 Rating:
Did your problem get solved? if yes, then will you please share how you did that. it would be really helpful.
5/3/2023 4:40 PM | |
Can you share how you did that please? |
