10/13/2016 4:47 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by AutoGen_944374 is split to a separate thread with the subject Busy output stays on if resetting communication. Best regards |
6/2/2017 10:25 AM | |
Posts: 11 Rating:
Hi Duris, Sorry but I'm still confuse, I am new in this field and I'm still learning thru any internet site. That's why I am seeking for further explanation. I don't get the point of putting a counter in done output ? I have a power meter and I want to get the values from the power meter thru a modbus rtu communication. I have CB 1241 RS 485 communication board. My Comm_Load blocks is working fine but my problem is in my master blocks it is always in busy mode. I put an auxiliary ( NO ) and a set output to knew if it is true that the master blocks is done but in a very short time. And yes it's true that master blocks executed in done mode but where the data ??? I didn't receive data from the power meter. Probably the data will stored in Data blocks. But my data blocks is empty. No data executed. I hope you can help me with this Duris, I'm stock with this program for a week. And I'm hopeless. I've attach print screen photos of my program. Thank You. AttachmentDoc1.docx (635 Downloads) |
6/2/2017 10:57 AM | |
Posts: 2826 Rating:
mopS04: Neither the S7-1200 nor a *** would understand STL. |
