5/26/2010 10:21 AM | |
Joined: 10/7/2005 Last visit: 3/17/2025 Posts: 3042 Rating:
Hello Plant2PC you can "simulate" Profibus values with PLCSIMby putting in any values for any of the I/O addresses and won't even need the S7 PLC hardware for this. If you are aftera more sophisticated simulation of your Profibus Network, you can also spend some real money and buy SIMBA Profibus(now you will need the S7 CPU now though). Neither of the above helps with simulating Modbus though, if you google "Modbus Simulator" you will however find plenty of PC based application that can do this(in which case you will also have to have the S7 PLC hardware in place though). I hope this helps |
Cheers |
8/1/2015 2:21 PM | |
Posts: 1 Rating:
Hello, Could you please send me the Modbus Simulator that you mentioned? Thank you |
