7/5/2024 5:32 AM | |
Posts: 2 Rating:
Hi Danil, I have the same problem. Have you solved this problem? If yes, could you please share the solution Thanks ! |
7/8/2024 11:40 AM | |
Joined: 8/3/2009 Last visit: 3/25/2025 Posts: 15062 Rating:
Hello check the Basic application example, perhaps there are some useful information: https://support.industry.siemens.com/cs/de/en/view/68202723 Bye Murof |
