6/28/2017 1:13 PM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, I don't see reason to say that it must be done programatically. System is functional with very identical system like in CP341 Modbus programming, so defining init DB where is defined all required like Slave address, FC code and other needed data depended to request. Then you call Send block with your DB defined and receive via RECV to DB receive block. Don't understand what your colegue meaned. You can also find documentation about Modbus programming with ET200S DF11 CM here on forum somewhere and read all what will be important for you. Update: eeeeeehm now I don't understand why you ask this question because in this your topic you mentioned that aal is working ok with ET200s: MODBUS RTU - will it work on this way |
6/28/2017 2:26 PM | |
Joined: 9/16/2013 Last visit: 1/5/2024 Posts: 511 Rating:
It does works, but programs in our company are done by all of us. Since program for MODBUS RTU with ET200s as master has been done by someelse and that someelse told me that its way harder to configure program than in s7-1200 I posted this question.Yes his program works fine but I am trying to see what should be different than in s7-1200 |
Website: |
6/29/2017 3:31 PM | |
Hello, https://en.wikipedia.org/wiki/Device_driver |
With best regards... |
