5/1/2016 4:03 PM | |
Posts: 3 Rating:
hello. I got the same problem, With normal library as Modbus I can make a RTU comunicacion with s71200. and it works perfectly! but when I use the other library called MODBUS RTU. It doesnt work,.STATUS 7000. Anyone has experience with this issue? Thank you Best regards. ------------------------------------------------------------------------------------------ |
Last edited by: Blue Moderator at: 5/1/2016 6:03:39 PMNew subject after splitting |
6/5/2016 12:16 PM | |
Posts: 4 Rating:
Hi, Have you seen this example? I suppose is your case... bye bye |
6/5/2016 12:57 PM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, meanwhile we've tested that library and it Works also on S7-1200, some other interesting infos: https://support.industry.siemens.com/tf/ww/en/posts/147949/ |
With best regards... |
