8/6/2010 8:58 AM | |
Joined: 4/24/2006 Last visit: 3/21/2025 Posts: 8904 Rating:
When you have one slave, it is not relevant. When you have more slave's you should use RS485.
When you want to use Modbus RTU as protocol, you need to buy Loadable driver and dongle. Unless you write your own driver.
None of them, when you want to use Modbus RTU. Or the mentioned slave can communicate through another protocol.
Perhaps this manual can help: SIMATIC S7-300/S7-400 Loadable driver for Point-to-Point CPs: MODBUS protocol, RTU format, S7 is master Best regards, Wizard |
2 thankful Users |
8/6/2010 6:24 PM | |
Joined: 3/17/2010 Last visit: 11/10/2023 Posts: 29 Rating:
Thanks Wizard. Your answer helped a lot to clarify my concerns. |
