10/21/2011 5:02 AM | |
Posts: 1 Rating:
Hello All I am trying to write a program using the S7 1200 as master and several drives as slaves. I am looking at the example in the following link. I am using Basic 10.5 and waiting for my Communication Module. https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=47756141&caller=view Correct me if I am wrong. I see in the first network we set up the comm module, in the second network we set the address ect... the third, forth and fifth network is use as a sequencer for multiple reads and writes. Correct? And for every read and write I will need a seperate sequencer, or is there a better way? As this seems to be a lot of programming if using several slaves. Any help is apperciated. Newbee |
2/10/2016 10:20 AM | |
Joined: 6/1/2009 Last visit: 1/4/2023 Posts: 27 Rating:
Hi Expert I have problem same these. if you solve it , can you or anyone help me? thanks |
S.H.O |
