2/23/2011 9:24 AM | |
Joined: 4/24/2006 Last visit: 3/25/2025 Posts: 8905 Rating:
Dear k.k, Here is a link to manual: SIMATIC ET 200S Serial interface modules See chapter 3.6 for more information. Best regards, Wizard |
3/6/2011 12:45 AM | |
Joined: 10/7/2005 Last visit: 3/25/2025 Posts: 3042 Rating:
Hello k.k Wizardprovided you with.
It is very detailed and has (should have) all the info you need. Having said that, a general understanding of Modbus and its Function codes does help too and you'll find plenty of helpful material at http://www.modbus.org/. Last but not least, Modbus related question appear quite frequently on the Siemens Forum, just in case you haven't done so already you canfind them - together withFAQ's - with a search at https://support.automation.siemens.com. I hope this helps |
11/4/2015 11:10 AM | |
Joined: 8/21/2014 Last visit: 3/25/2025 Posts: 1035 Rating:
New question published by mushtaq is split to a separate thread with the subject Writing values by Modbus master using ET200S. Best regards |
