9/13/2010 8:18 PM | |
Joined: 9/27/2006 Last visit: 3/22/2025 Posts: 12344 Rating:
Hello crystal_group; Might I, very respectfully, suggest you access the S7-1200 manual? http://support.automation.siemens.com/WW/view/en/39710145 The MB_SLAVE instruction allows your user program to communicate as a Modbus slave. A Modbus RTU master can issue a request and then your program responds via MB_SLAVE execution.Inserting the MB_SLAVE instruction creates an instance data block.Use this DB name as the MB_DB parameter on the MB_COMM_LOAD instruction. Or you could alternatively search the forum site for more help from members: /tf/WW/en/Posts/46550 Hope this helps, Daniel Chartier |
