10/7/2008 11:48 AM | |
Posts: 2 Rating:
Hi. I wrote earlier that the modem does not react to button SET.I have found a theme in a forum with precisely same problems. /tf/WW/en/Posts/15756#top 2. There is a known issue with those running light. I hope its not the same with your modem But when you attach only the powersupply (no modemcable, no ppi-cable) and the running light bersists all the time. Even when you press the "SET"button then you should send the modem to your local support / or open a support request. You will get a new modem then free of charge when you send the old broken modem to them |
