5/24/2018 8:23 AM | |
Joined: 7/9/2015 Last visit: 3/21/2025 Posts: 4204 Rating:
Hi, in the settings of CP you can activate "Module replacement without PG" so I think CP gets projected IP-address after restarting the PLC. Best you check manual for more detailled information about changing IP-Address (i.E. Page 59) PROFINET CP 343-1 Manual Manual part BTowome |
5/24/2018 2:44 PM | |
Joined: 1/15/2018 Last visit: 3/21/2025 Posts: 148 Rating:
Hi, Thank you for your answer, but i found that i cannot do that because the proyect have the setting "Set IP address in Properties" and not "Set IP address in user program", so you change the IP, when the plc restart, will change the IP again. How can you configure an S7 CP during runtime? Best regards, Gonzalo |
