4/21/2013 11:22 AM | |||||||||||||
Posts: 621 Rating:
Hello. Have you checked wiring connection diagram and go throgh the attached file wheter s7 hard ware configured and downloaded check it call hardwre inturrupt OB block Attachmentet200s_im151_1_standard_manual_en-EN_en-US.pdf (25 Downloads) |
4/22/2013 7:34 AM | |
Joined: 1/21/2013 Last visit: 4/21/2023 Posts: 4617 Rating:
Hi automation.patel, what problem do you have? how are the LEDs SF, BF? you should explain better. |
5/2/2013 12:59 PM | |
Posts: 20 Rating:
hello sir thanks giving me a replying so as per your instruction i can cheked all wiring as per your attechment .so all wiring also find ok .when i happend the problem at the time LED i show on im 151 as sequence the sf led is on/off 3 time then bf led on/off 1time and supply LED is continus on .after that i can chnge all module one by one and power on and off machine when the sequence LED goes off and supply LED continus on at the time PLC turn in run mode then we use machine in production. |
5/3/2013 11:18 AM | |
Hello automation.patel, Let us know the diagnostic buffer |
