3/18/2010 1:08 PM | |
Posts: 5 Rating:
Hi everybody Order No./ Description Component Version Rack: 0
Order No./ Description Component Version DP master system: 1
AttachmentHW-Config.pdf (437 Downloads) |
3/22/2010 1:19 AM | |
Posts: 16 Rating:
Hello remember that you are using a fail safe module. i think the problem is wiht the load conected to the ouput. (please see the chart). if you can install a ouput interface relay i think will be the solution. i would like to knoe if you can make the change bye Attachments7300_failsafe_signal_modules_manual_en-US_en-US[1].pdf (1576 Downloads) |
8/31/2014 11:19 PM | |
Joined: 9/1/2005 Last visit: 8/24/2023 Posts: 4102 Rating:
new question published by Uppiis split to a seperate thread with the subject profibus fail of 300 ms 2 times a day. Best regards CS Moderator |
