1/20/2011 1:17 PM | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posts: 3609 Rating: (29) |
1/26/2011 1:13 PM | |
Posts: 86 Rating: (7) |
Please explain your questions. What are the big issues? Yer |
1/26/2011 10:55 PM | |
Posts: 1 Rating: (0) |
Which products should you choose to Siemens ? |
1/27/2011 6:34 PM | |
Joined: 9/27/2006 Last visit: 9/15/2024 Posts: 12282 Rating: (2683) |
Hello saka; Not knowing much about Moeller's PLC selection, it is difficult for me to give you direct conversion information. However, if yoiu follow this link to Siemens' Interactive Catalog, you should find enough information for at least a basic search. This should be refined with the helpo of your local Siemens rep, who should be able to fine-tune the configuration: https://eb.automation.siemens.com/goos/Catalog/Pages/ProductData.aspx?activetab=&language=en&nodeid=5000013®ion=fi®ionUrl=%2fbe&tree=CatalogTree#activetab=product The llink will open up an information page on the S7-300 family of PLCs, which I am presuming should cover your requirements. If I am wrong there, use the navigation options to look at other families and their caracteristics: S7-200, S7-1200 and eventually S7-400. You canalso locate information on HMI panels to complete your project. On the page you arrive on, you will find a page of product information on the S7-300, and multiple links to specific data and part numbers for, say Digital Input modules (through the Signal Modules link) or CPUs . Once you have determined the type of modules required you can use the Configurator tab to build a sample configuration f0or your project which will give you all details on the accessories needed. We on the forum can also help with specific information you would need to clear up details. Hope this helps, Daniel Chartier |
