8/25/2015 2:26 PM | |
Joined: 6/3/2014 Last visit: 1/17/2023 Posts: 660 Rating: (193) |
Well, the way I understand it there are two parts to this, you need:
to 1.) This lifebit toggles constantly. If you use a counter: after a certain time limit you can look if you have the right value and accordingly set/reset your own boolean tag. (For example "PLC_1_connected 1=connected, 0=not connected", same for "PLC_2_connected".) to 2.)
... mostly about WinCC flexible, but should work similar enugh.
Last edited by: H.J. at: 8/25/2015 2:27:31 PM~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ★ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ |
