8/26/2014 11:55 AM | |
Posts: 12 Rating:
ok. Thank you! I made a simple drawing which shows my problem. Do you have any idea of solution? /Sara
AttachmentOverview.pdf (62 Downloads) |
8/26/2014 12:14 PM | |
Posts: 1368 Rating:
Hello, you must insert a router between network 10.46.xx.xx and 192.168.1.xx. For example S602. This module have 2 ports: red: external network green: internal network you can allow communication from ext -> int or int-> ext via firewall in s602. http://support.automation.siemens.com/WW/view/de/48155707 Example: http://support.automation.siemens.com/WW/view/de/22376747 |
8/26/2014 1:54 PM | |
Posts: 12 Rating:
