6/11/2021 8:26 AM | |
Joined: 4/28/2015 Last visit: 12/5/2023 Posts: 3297 Rating:
Hi, since you are not sure whether the certificates are created correctly, I can suggest to use this tool to create the certs (CA, client and server). There is a GUI and it is easy to use. After you need to place this files poperly in the mosquitto.conf. I am not sure how this exactly looks, but I guess your config looks not bad. Did you also place the certificate to the TIA Portal / PLC as described in the MQTT application example documentation? I will try to test this today, hopefully I can find the time. Best regards! |
6/11/2021 11:41 AM | |
Hi, means your connection works now with SSL encryption? Best regards! |
