5/18/2022 5:02 PM | |
Joined: 6/10/2015 Last visit: 2/12/2025 Posts: 471 Rating:
Hi, your question is too general, so I restrict my answer to what I suppose your best choice may be. The only thing I can suggest you is to look for Technology Objects in TiA, You can link them to a hardware (your drive) if they can use profinet telegrams such as Telegram 3 or Telegram 105. Technology objects are a layer provided by Siemens in TiA that helps your application connect and correctly use your hardware. In your application you can interface your program using motion control instruction library. BE Attachments71500_s71500t_motion_control_overview_function_manual_en-US_en-US.pdf (372 Downloads) |
Last edited by: BoletusEdulis at: 05/18/2022 17:04:02Last edited by: Jen_Moderator at: 05/19/2022 09:39:56Video embedded. PDF from link added as an attachment. B. Edulis |
