1/26/2022 7:41 PM | |
Joined: 6/3/2013 Last visit: 7/20/2022 Posts: 50 Rating:
Hi, I recommend reading this manual: SIMATIC/SINAMICS Getting started with SINAMICS V90 PN on S7-1500 Motion Control |
Last edited by: Jen_Moderator at: 01/27/2022 06:00:25Optimized link. And you will know the truth, and the truth will set you free. |
1/27/2022 9:40 AM | |
Joined: 11/4/2011 Last visit: 12/19/2022 Posts: 157 Rating:
Hi, But as far as we can see you are talking about S7-1500 Motion Control with the according technology objects which you show in your screenshot. Generally you have this overview page for the motion control topic: https://support.industry.siemens.com/cs/de/en/view/109751049 From here I'd say it depends on how you like to learn. If you're better with manuals that show the theory behind it, you might start with the manuals (first links on the page mentioned above). If your better with learning from examples, then check the application examples. The most basic start is probably this video: https://support.industry.siemens.com/cs/de/en/view/85078044 I myself like this application example, as it explains the technology objects very well, even for a beginner: https://support.industry.siemens.com/cs/de/en/view/109743134 As this document only describes the technology objects, you might need to also learn about the rest of the motion control, such as programming, commissioning, how process image and runtime system works. For this I recommend the official documentation, simply because I myself have not found anything shorter or simpler than this. The document I'm talking about is this one: https://support.industry.siemens.com/cs/de/en/view/109781848 |
2 thankful Users |
