11/4/2012 2:29 PM | |
Posts: 3 Rating:
Im trying to use a motor runtime accumulator FC, and a Motor Ordering FC to run the motor with the least amount of Hours run, Im trying to asign the Motor1_TimeToRun to energize the duty Contact inside my Pump 1 start Block, and the Motor2_TimeToRun to energize the duty contact inside Pump 2 start block I have attached the Pump start block and my Motor ordering FC, if you could please give me detail on how i could energize the duty Bool byte from the Motor 1/ Motor 2_TimeToRun byte ? Thank you AttachmentPump Block.zip (388 Downloads) |
11/5/2012 2:00 PM | |
Joined: 9/1/2005 Last visit: 4/10/2025 Posts: 4113 Rating:
closed cause question posted twice. The second thread with the subject how i could energize the duty Bool byte from the Motor 1/ Motor 2_TimeToRun byteis published within the conference STEP 7 (TIA Portal). Best regards CS Moderator |
