11/26/2018 10:03 AM | |
Posts: 6 Rating:
Posts: 6 Rating:
11/26/2018 10:05 AM | |
Posts: 6 Rating:
12/10/2018 5:45 PM | |
Posts: 6 Rating:
Hello It is for a 4-axis continuous machining center heidenhain TNC 426 with motor and variator siemens. here is the link https://youtu.be/nqINtXyxwU0 this is an explanatory video you will see all the material in details (sorry it's in french) With this video, you will understand all. Thanks in advance Noted well: on this milling machine there was a divider 4th axis of the same type. This divider has been sold (apart) So I bought a similar divider, the machine is predisposed, the auerbach milling machine has all to receive the divider 4th axis
Last edited by: criss59 at: 12/10/2018 5:49:06 PMLast edited by: Jen_Moderator at: 12/11/2018 9:07:34 AMInserted video. |
12/12/2018 8:33 AM | |
Joined: 10/17/2007 Last visit: 3/19/2023 Posts: 3276 Rating:
I try my best to help you--I don't know French language but tired to use Google Translation TNC426 made by Heidenhain which possible use Siemens SIMODRIVE power supply and axis power section in drive system. Luckily I have some experience for service this kind of machine, But only for the drive part, I have no idea for CNC interface. I will suppose this TNC 426 can supply analog output command (+/-10V) to interface drive. (you need check Heidenhain manual by your self) In this condition I suggest you to use SIEMENS 611A control card 6SN1118-0AA11-0AA1, the drive box--we call power section if your system has no more available, you can purchase a 25A drive box 6SN1123-1AB00-0BA1. for servo motor you must use 1FT5...MOTOR, for detail selecting motor. I attached manual , which including mechanical, frame, seize and so on you should match motor to drive and frame by you self, then search the motor in the market Siemens already discontinued 611A system (card and motor) when you find out the motor number, post here I will double check for you AttachmentMOTE.SIE 1FT50621AC71EA_1.pdf (107 Downloads) |
Last edited by: nulizhang at: 12/12/2018 8:35:19 AMPM me I can show you where to get hardware Please Help me to understand your question! |
