12/6/2011 2:48 AM | |
Posts: 7 Rating: (0) |
dear huggy_d1, |
12/6/2011 2:43 PM | |
Joined: 7/7/2010 Last visit: 12/11/2024 Posts: 15491 Rating: (2456) |
You can try it both ways with a factory reset in between. Monitor the motor performance both ways and pick the method that suits. Then you will be the experts on your specific system. One thing to remember is that once you get a successful motor id, you should perform it at few times, noting the motor characteristics parameters after each run. They should get better with each run until it starts to oscillate around the most accurate data. Best of luck. |
science guy |
