9/12/2014 2:26 PM | |
Joined: 1/21/2013 Last visit: 10/31/2022 Posts: 4617 Rating:
Hello ali_alkarn Have you already seen this: How do you copy memory areas in STEP 7 (TIA Portal)? or how can I move block byte or word, Dword... in S7-1200 program ... |
9/12/2014 2:41 PM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
Just add small point, For S7-1200 functions " MOVE_BLK","UMOVE_BLK" support data transfer via DBs and local memories.Read more HERE.As S7-1200 has been used for Micro-automation,With limited analog signals in a machine, I suggest using MOVE function to transfer inputs to memories.You also have option of testing FOR loop in SCL with indirect addressing to automate transfer task.Try it for S7-1200 in TIA V13
Note,TIA V13 also supports "BLKMOV" for S7-300/400 with same functionlaity as explained before. |
Last edited by: hdhosseini at: 9/12/2014 2:47 PMLast edited by: hdhosseini at: 9/12/2014 2:43 PM |
9/13/2014 1:11 PM | |
Joined: 4/3/2014 Last visit: 9/9/2022 Posts: 54 Rating:
DearWilliam B.hello, Best regards
