4/15/2013 3:22 PM | |
Posts: 3037 Rating: (192)
Hello, You can use the function "export datarecords" to copy datarecords to a USB stick. For logs: You can use this link: How can you safely copy or move archives in WinCC Comfort V11/WinCC Advanced V11? Tweety |
10/1/2016 8:21 AM | |
Posts: 14 Rating: (0) |
I have the same problem, I can not copy all the files from SD to USB. Some expert can tell if this is a limitation of the comfort panel? Thank you Valter |
11/15/2016 8:11 PM | |
Joined: 6/18/2013 Last visit: 3/9/2022 Posts: 1 Rating: (0) |
Hi, format USB to system FAT32. |
