6/27/2015 9:49 AM | |
Joined: 11/29/2011 Last visit: 10/25/2023 Posts: 1348 Rating:
Hi, Just a quick thought: Left/Top? If you use "ScreenWindow" maybe you will find interesting the WinCC Professional V13.0 manual for example at page 5117. You can read description next to Left property: "Specifies the value of the X coordinate of the object." Top property: "Specifies the value of the Y coordinate of the object." Please let us known how did you solved the issue! I hope I could help! |
Last edited by: MicroMan at: 6/27/2015 9:59:05 AMRephrased my comment! Last edited by: MicroMan at: 6/27/2015 9:56:34 PM- What you read here, please check with manuals and your requirements. |
6/29/2015 6:56 PM | |
Hi, The Top/Left properties should be accessible via for example VBs. In the case you want to see an example how to access object properties from VBs, there is plenty of example in the WinCC Professional V13.0 manual. For example under chapter "10.8.9.3 Example of defining object colors". Also the syntax for the Left property described on the page 5339, the syntax for the Top property described on the page 5661. I hope I could help! PS: just found an example for you in WinCC V6 VBS Reference Printout of the Online Help under chapter "1.2.2.4 Picture Window". |
Last edited by: MicroMan at: 6/29/2015 7:10:23 PM- What you read here, please check with manuals and your requirements. |
2 thankful Users |
