8/30/2016 2:32 PM | |
Joined: 5/12/2006 Last visit: 2/18/2025 Posts: 22544 Rating:
Hi, you must Migrate the old Panel to TIA Portal and then change it top TP1200. For the Migration you need WinCC Flexible and WinCC Tia Comfort on the same system so you can easy migrate the WinCCFlecible project to TIA Portal Here a description for this procedure: https://support.industry.siemens.com/cs/ww/en/view/77430539
Christoph |
