5/24/2014 10:36 PM | |
Joined: 1/21/2013 Last visit: 3/13/2023 Posts: 4617 Rating:
There is a problem!!
5/25/2014 8:50 AM | |
Posts: 784 Rating:
Hello, Backup done by prosave restore to the same panel type. You shoud make the backup using WinCC flexible then migrate it into TIA Portal. If not possible ,contect the manufacturer to take the original program for HMI otherwise you start theprogrammimg from the first. Best regards..... |
5/25/2014 12:01 PM | |
Joined: 9/7/2007 Last visit: 2/22/2023 Posts: 550 Rating:
HiWago If you have the configuration file there will no problem. The problem is thatDa!:
and that is why he created this thread to find a solution to his problem.
Best Regards |
