9/21/2012 4:12 PM | |
Posts: 3037 Rating:
Hello Northman, Does the panel work ok in the moment? Or You can start the panel, the error appears always. Which version of WinCC flexible do you use? Do you log tag or alarm on a memory card? Do you use many script? You should do an operating system update with reset to factory setting. How do you do an operating system update (OS update) on operator panels? Tweety |
9/21/2012 8:30 PM | |
Joined: 5/28/2008 Last visit: 2/12/2025 Posts: 4518 Rating:
Hello, Did you tried to make re-calibration?
Ayman Elotaify |
