5/27/2009 12:44 PM | |
Posts: 23 Rating:
Hi, The clock of panel MP277 is late about 10 minutes in a day. Where could be the problem? OS: Mobile_MP277_V1_0_0_0.img Arvydas |
5/28/2009 9:55 AM | |
Joined: 5/8/2006 Last visit: 10/16/2024 Posts: 1085 Rating:
Hi the MP277 has an hardware clock inside. You can synchronize clock of the plc with the clock of the panel. Maybe this FAQ will help you: http://support.automation.siemens.com/WW/view/de/24104104 If you use WinAC MP, then i would send the panel to the repair center. Link: http://support.automation.siemens.com/WW/view/de/22639376 Bye |
6/1/2009 10:40 AM | |
Posts: 23 Rating:
Hello, maybe this is one of the way how to work around this problem. But the panel should work correctly by itself :) Arvydas |
