12/12/2011 2:39 PM | |
Posts: 3037 Rating:
Hello, Which WinCC flexible version do you use? Here is the FAQ for image update. How do you do an operating system update (OS update) on operator panels? Do you do this? Tweety |
12/13/2011 3:51 PM | |
Posts: 3037 Rating:
Hello, You can take a look at following FAQ. How do you backup/restore with a Windows-based panel? Tweety |
11/30/2015 10:44 AM | |
Posts: 38 Rating:
Dear All, I have the same problem with runtime. The Runtime can not be started on the panel and also on the PC. Thanks for your advices. Murat |
11/30/2015 2:39 PM | |
Posts: 38 Rating:
After I transfer the program to panel then after rebooting came this warning: flash/simatic/PDATA.FWX could not be loaded.... |
11/30/2015 8:30 PM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello muratarat, for the 99 percent you do not have the memory card in the panel right? For me this is the problem because I had the same problem today https://support.industry.siemens.com/cs/document/29054992?lc=en-ww
Last edited by: Ste39 at: 11/30/2015 8:31:20 PMLast edited by: Ste39 at: 11/30/2015 8:41:00 PM |
