7/29/2009 4:13 PM | |
Joined: 5/8/2006 Last visit: 10/16/2024 Posts: 1085 Rating:
Hi You should check the busaddresseswith diagnostic function of the PC/PC adapters. If you don't see the hmi device, you should check the cable, baud rate, etc. Do you want to transfer your WinCC flexible project to the MP277B or do you want to establish a connectio to a plc? If you want to transfer your project, maybe this faq will help you: http://support.automation.siemens.com/WW/view/en/23802404 If you want to establish a connection to the plc, maybe your connection settings are not correct. Bye |
7/31/2009 9:04 AM | |
Hi I don't know what do you mean with port 1 and port 2 but I am pleased that you slove your problem. Bye |
