10/4/2010 2:50 PM | |
Joined: 9/27/2006 Last visit: 3/22/2025 Posts: 12344 Rating:
Hello pauks; Strange, normally as soon as the GD tables are downloaded to the CPUs and they are in Run Mode the exchanges should start, in my experience. Why don't you look at the following FAQ on GD communications, and check out the step-by-step implementation document attached; use it as a checklistto troubleshootyour own application. http://support.automation.siemens.com/WW/view/en/430498 If it does not help, please place a screenshot of Netpro in your project and one of the GD table, even if you can show it all. Hope thios helps, Daniel Chartier |
10/4/2010 2:54 PM | |
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
Hello, Check your settings according to - http://support.automation.siemens.com/WW/view/en/25734677 Also check there - http://support.automation.siemens.com/WW/view/en/25735422 Best regards, Hristo Mihalev |
10/5/2010 3:40 AM | |
Posts: 8 Rating:
Hi, I don't try your advive with PLC, but today i try it. Now i attached Screen shot of NetPro and GD table. This signal in REAL format. Also i need three bit but they not filled in now. Two bits from one and one bit to another PLC.
AttachmentNetPro.pdf (107 Downloads) |
