8/24/2013 6:48 PM | |
Posts: 47 Rating: (4) |
Well assuming that it is possible to conect these devices on your subnets MPI and DP. First of all you need to find GSD files of this devices normally you can find it at manufacturers webpages. Some information about GSD files: http://www.profibus.com/products/gsd-files/ Then you need to install this GSD files in STEP 7, follow this tread: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=22834942&lang=en&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=WW Now you are able to integrate these third party device on your HW Config.
Note: Very important that you find the correct GSD file, most of the times faults occurs just because you didnt install the right GSD file. Regards. |
