10/10/2018 6:04 AM | |
Posts: 47 Rating:
Help me please! |
10/11/2018 11:52 AM | |
Posts: 1368 Rating:
Hello, please read the notes in the document you find under Documentation and project example for an secure messaging (S7-1500) on the MQTT entry page. https://support.industry.siemens.com/cs/de/en/view/109748872 Especially page 18 and 21 |
10/11/2018 5:06 PM | |
Posts: 47 Rating:
Thank Pittiplatsch for you reply. My actual problem is to combine the Client.key and Client.pem to a single file (Client.p12) to import to Global Certificate Manager (TIA Portal). I've tried some methods on the internet, but it does not work (MQTT FB shows certificate error code). Please give me some recommendations. Thank you |
10/12/2018 6:01 PM | |
Joined: 10/7/2009 Last visit: 3/6/2025 Posts: 266 Rating:
Dear minhkhanh, If the MQTT FB shows a certificate error code, I think the problem should come from the MQTT broker side. If you are connecting to AWS IoT, make sure that you have registered your CA Certificate. Please follow the instruction of AWS IoT - Use Your Own Certificate or contact with AWS Support for help. Best regards, Yu-wen |
10/13/2018 9:55 AM | |
Posts: 47 Rating:
Dear Yu-wen Tang, Thank you for your reply. I'm sure that all certificates are OK (as I can connect to AWS via MQTT.fx application by using these certificates). The problem is combination private key and client certificate. Have you ever worked with AWS, Tang? |
