10/25/2023 2:53 PM | |
Joined: 5/30/2022 Last visit: 11/29/2023 Posts: 440 Rating:
Hi maxhottars, I recommend you to update to the latest update of TIA PORTAL V18, to solve the error both project and image version of the panel: Updates para STEP 7 V18, S7-PLCSIM V18 y WinCC V18 How do you delete the IM folder of your STEP 7 (TIA Portal) project? |
If this information really helps, you could use the Rate function. |
