7/13/2023 6:26 PM | |
Joined: 1/21/2013 Last visit: 9/25/2023 Posts: 2056 Rating:
Hi all, If you use EjectStorageMedium, you should read the note in the documentation. The system function only works correctly in runtime if you use the storage medium in question for logging. I know there is a good working solution using the sync command. Unfortunately, I do not know the details, but technical support should. Kind regards |
