12/15/2023 7:41 PM | |
Joined: 4/26/2012 Last visit: 7/24/2024 Posts: 1547 Rating:
Hello, welcome to the forum. Did you drag the I/O field from the toolbar, a new one or copy it? What is the version of TIA? Have you tried deleting the HMI folder and recompiling everything? How do I delete the IM folder of your TIA Portal project? LINK good luck.
Last edited by: rdoliveira at: 12/15/2023 19:43:19edit link Last edited by: rdoliveira at: 12/15/2023 19:44:25edit Last edited by: rdoliveira at: 12/15/2023 19:47:16"Always make a backup before and check the best time before testing." |
12/18/2023 2:30 PM | |
Joined: 6/20/2022 Last visit: 1/18/2024 Posts: 3 Rating:
Hello rdoliveira! Thx for replying. I drag it from the toolbar, but even after delet the IM folder it still doesn´t work. I use TIA v16. Thank you |
12/22/2023 8:59 AM | |
Joined: 8/3/2009 Last visit: 7/26/2024 Posts: 13385 Rating:
Hello netoo88 you are working with a quite old TIA Portal Version... Do you have installed at least the latest Upd for your TIA V16? https://support.industry.siemens.com/cs/de/en/view/109775861 Bye Murof |
