7/5/2023 1:21 PM | |
Joined: 8/17/2022 Last visit: 4/15/2025 Posts: 15 Rating:
Hello, I'm using a WinCC MTP700 unified panel, but this doesn't work either. I'm on v17. Do I need a setting to use multitouch function? Where could that be if Yes? Many thanks, T. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/06/2023 07:55:09New subject after splitting. Quote inserted. |
7/6/2023 8:17 AM | |
Joined: 1/21/2013 Last visit: 4/19/2025 Posts: 3765 Rating:
Hi EL_T_M, You are using an MTP, a Multi-Touch Panel. So multitouch is always enabled. However, it is not supported to trigger a press event for two buttons, except for two-handed operation with an enable button. Kind regards |
