4/9/2020 10:17 AM | |
Hello Perhaps you can work with Address multiplexing?? There is no FAQ for TIA but one for WinCC flexible (its quite the same in TIA Portal) https://support.industry.siemens.com/cs/ww/en/view/21808320 Bye Murof |
