11/23/2006 11:29 AM | |
Joined: 11/22/2006 Last visit: 3/29/2023 Posts: 7 Rating:
Hi, Any software-accelerations and the drivers are signed with Microsoft. Fred |
11/23/2006 5:25 PM | |
Posts: 3149 Rating:
Hi, well, as mentioned Siemens recommends to use another VGA-card, yours certainly has not been tested in combination with WinCC. But perhaps the following FAQ can give some ideas: http://support.automation.siemens.com/WW/view/en/20712944 http://support.automation.siemens.com/WW/view/en/14564777 nemo |
11/23/2006 5:56 PM | |
Ok, I will make some testes!! Thanks the help!! Regards, Fred |
3/12/2009 9:49 AM | |
Joined: 10/18/2006 Last visit: 3/4/2022 Posts: 163 Rating:
I had the same problem PCS7 v6.1 SP1 and after upgrading to SP2 the problem was solved. Good luck. Cheers |
