11/14/2017 9:24 PM | |
Joined: 9/27/2006 Last visit: 3/22/2025 Posts: 12344 Rating:
Hello jolter; The nature of your question is not clear tp me. Based on the drawing you have attached, I would think that you are trying to decide if you need a line structure or a star topology for your Profibus network. If that is the case, you must take into account the fact that Porofibus is designed normally for line topologies, in daisy-chain construction with Profibus cable and Profibus connectors, as you depict in the top part of your schematic. If you wish to implement a star structure, you need to add a star hub module between the TP1200 and the CPUs, something like Procentec's ProfiHub: https://procentec.com/products/profihub/units/profihub-b5plusr/
Hope this helps, Daniel Chartier |
11/15/2017 10:08 AM | |
hi jolter ggg, Profibus only allows line-topology For other topologies you need other active components like repeater have a look to the Profibus Network manual hope this helps, regards, |
FCK WAR! |
