6/9/2015 3:22 PM | |
Joined: 8/3/2009 Last visit: 12/4/2023 Posts: 11798 Rating:
Hello tressian you cannot use for all functions in TIA portal Tags with adressMultiplexing As a trigger Tag you cannot use this. You have to use a "normal" Tag or a Array Tag. Perhaps you can use the following FAQ for your Use Case: https://support.industry.siemens.com/cs/ww/en/view/35508221 its a flexible FAQ but in TIA its probably the same. Bye Murof |
