1/27/2008 7:43 PM | |
Posts: 5822 Rating:
Hello, I think what you need is PG Routing over a PC Station. There you need SIMATIC NET running on the PC that is connected to both Ethernets. Than you can use this PC as Gateway.. but the Problem is, I think, that you may need a Hardnet CP because SIMATIC NET does not support two NICs at a time. See this FAQ: Which requirements have to be fulfilled to perform a STEP 7 Routing via a PG/PC Station? I hope this will help. Best regards J_Bell |
