10/29/2015 12:58 PM | |
Joined: 5/28/2008 Last visit: 6/19/2023 Posts: 1343 Rating:
Hi,, the functionality about the CPU Display you can read here in chapter 12 https://support.industry.siemens.com/cs/de/en/view/59191792
In General you are able to make diagnostic and maintenance. So you can see, where the fault is in your automation system. Furthermore you can watch the diagnostic buffer. Or you can reset the PLC or change IP-Address. But you will not see the PLC Code and you can't modifiy the program. |
10/29/2015 11:12 PM | |
Joined: 3/28/2015 Last visit: 9/30/2023 Posts: 716 Rating:
Hello, Perhaps the following topics might help: 1-Which license do you need to upgrade from STEP 7 version V5.x, V11 or V12 to the TIA Portal V13? |
Eng.Mohamed Ibrahim |
