10/28/2008 4:35 PM | |
Joined: 9/27/2006 Last visit: 7/26/2024 Posts: 12270 Rating:
Hello Ton; Johnson Controls Metasys N2 serial protocol is used in HVAC applications, to connect a ontroller with fan drives, dampers, energy meters, etc.... I believe some Siemens Building Automation lines support the protocol (I believe Desigo has a module for that) but that would not help you at this point. I would look for some kind of gateway for this project. I have used Fieldserver in certain projects (www.fieldserver.com), they offer selectable protocol gateways; they mention N2-Profibus-DP converters, or N2-Modbus onm the website. See this explanation of gateway possibilites with their products. http://www.fieldserver.com/docs/pdf/Using_FieldServers_in_Metasys_N2_Applications.pdf Hope this helps, Daniel Chartier |
10/29/2008 1:13 PM | |
Joined: 4/20/2007 Last visit: 5/27/2024 Posts: 724 Rating:
Thank you very much. I'll look into it. But I suspect they'll choose for the cheap way out... Pot free contacts Ton |
