7/9/2016 6:39 AM | |
Joined: 1/28/2009 Last visit: 2/21/2023 Posts: 6794 Rating:
Dear Nate@SMS , To have a better discussion and providing strong reasons , we need to have your program section , test and see what would be the exact reason.About the limitation in floating point calculation , check the following link: How accurately can I calculate with REAL numbers that are used in extensive formulas?
The final point ,see if "Neperian logarithm" helps in case of multiplication of huge numbers by small numbers. I hope it helps, hdhosseini |
7/9/2016 10:21 AM | |
Posts: 8946 Rating:
result out of allowed numeric area / divison by Zero (?) |
7/9/2016 6:13 PM | |
Posts: 5225 Rating:
Hi there. I am very curious about this case.. What result did you expect? Sorry - TIA Portal is what I have available. Maybe someone wants to build on the code run on an S7-300 / S7-400? Greetings.
AttachmentS71200_SimResult_and_SCL_code.zip (71 Downloads) |
