6/23/2022 8:43 PM | |
Joined: 1/5/2022 Last visit: 7/28/2023 Posts: 10 Rating:
Could you please to help me to write the VBscript to create csv file for HMI TP1200 Comfort? .csv file should be located on SD card. I just need a simple code to locate the csv on in the HMI SD Thank you in advance ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/24/2022 09:40:03New subject after splitting |
6/24/2022 10:56 AM | |
Joined: 5/30/2022 Last visit: 4/16/2025 Posts: 634 Rating:
Hi Siemens_Repair_Man, I think that you can create excel directly by VBscript Be aware of your TP1200 OS: I think it is Win CE. There will be other functions (or syntax) for File-Object as in Windows 7. Please look at: http://www.cerrotorre.de/faq-script/faq-script-excel.htm Regards |
If this information really helps, you could use the Rate function. |
